Rickjones80
Sep 10, 2023Tutor
ReadyNAS 214 - Update error message
Hi I have a ReadyNAS 214 and currently when I click on the option to check for updates I get an error message (See attached screenshot). Is there anything I can do to rectify this issue? ...
- Sep 11, 2023
Rickjones80 wrote:
Everything else appears to be working fine, it is just the check for updates link that does not seem to be working
I'm seeing that also. It has happened before, and is a problem that Netgear needs to fix in their back end. After they fix it, it can take a day or so for the fix to propagate to the full internet.
Sep 10, 2023Guru - Experienced User
Rickjones80 wrote:
After checking the support page for RN214 I can see that the latest firmware version is 6.10.9.
Is it safe to update from 6.10.8 to 6.10.9
I'm running it on a few ReadyNAS (including an RN202) with no problems.
- Rickjones80Sep 11, 2023Tutor
I have updated to the latest firmware manually but the issue still remains.
- StephenBSep 11, 2023Guru - Experienced User
