trikky
Dec 28, 2024Aspirant
ReadyNAS 214 - Why is new Volume not appearing on my network?
Firmware 6.10.10. Check for updates, no new updates available ReadyNAS 214. I have added a new disk and created a new JBOD volume, but when I connect to the ReadyNAS through my network, I can't see...
- Dec 30, 2024
Try creating a share on the volume.
trikky
Dec 29, 2024Aspirant
Thanks, Stephen.
No shares on this volume. The only disk with shares on my setup is DISKY2. DISKY3 and DISKY4 don't have any shares at all, and they're running fine.
Yes, using an admin account - the only account I've used for several years, so no change there at all. This is a created account, with admin access, as opposed to the default admin account.
Dec 30, 2024Guru - Experienced User
Try using the default admin account - I think you will see it there.
- trikkyDec 30, 2024Aspirant
Thanks again, Stephen
Have logged in with admin, got the same results.
Just now I destroyed the 'old' volume 3B, and have created a new volume, 3A in the unlikely event that for some reason THIS volume needed to be created by the specific admin account. Don't know why I would of course, since I haven't used 'admin' since whenever.
No joy there, either, though, when connecting to the network with 'admin' credentials. As before, have 4 green lights on the console and everything is showing online when hovering over the disk representation on the console.
Currently running a disk test via the admin login, just for the sake of it, but doubt that will do anything at all.- StephenBDec 30, 2024Guru - Experienced User
- trikkyJan 02, 2025Aspirant
Well, I don't know if it was the disk test I was doing (unlikely, though), but while the disk test was running I did add a general share to the drive.
Hey, presto! Both the drive, AND the share I had created, magically appeared on all my network devices.
I have since deleted the share, and (not unsurprisingly) the drive is staying visible to all, and I can do my stuff with it.
So whatever it was, clearly creating the share triggered whatever needed to be triggered, for the volume to be visible to my devices. It wasn't the creation of the share itself as being a requirement - as previously mentioned, two other volumes don't have shares on them (and never have). But once the share was created (and I mean immediately it was created) all was resolved.
So thanks heaps for your input.We can note that creation of a temporary share is a good troubleshooting item if anyone else has this challenge...or if I ever get it again.
