kncowans
Apr 14, 2018Virtuoso
Readynas 214 compatible with the WD Red 10TB HDD?
Hello all I am looking to upgrade the storage in my RN214 which currently has WD RED 5TB HDDs. I was looking at the WD RED 8TB HDD but noticed there is now a 10TB RED, however the 10TB RED is...
Apr 14, 2018Guru - Experienced User
kncowans wrote:
Does anyone know if the 10TB RED is compatible with the RN214?
As you suggest, it should work. But I haven't seen any posts here from folks using this drive.
kncowans
Hello Stephen
Thanks for the reply.
Is there any way to contact Support with this query that would not require a charge?
Thanks in advance
Kevin
- StephenBApr 16, 2018Guru - Experienced User
Not that I know of. They don't do the disk certification themselves, so the most they could do is forward your query.
douglas_cheung - any chance that these disks will be certified in our lifetimes? :smileywink:
