kncowans
Apr 14, 2018Virtuoso
Readynas 214 compatible with the WD Red 10TB HDD?
Hello all I am looking to upgrade the storage in my RN214 which currently has WD RED 5TB HDDs. I was looking at the WD RED 8TB HDD but noticed there is now a 10TB RED, however the 10TB RED is...
n0Ob
Jun 01, 2018Aspirant
Hello Kevin - did you end up finding the answer to your question? I have the ReadyNAS 214 and I want to install the WD Red 10TB (5400) drive so was curious if that worked for you. Thanks.
- kncowansJun 01, 2018Virtuoso
Hello
Unfortunately I have not been able to find any answer to this question.
I have decided to hold off on upgrading my HDD until I can get a clear answer.
Sorry I could not of more help.
Kevin
- n0ObJun 01, 2018Aspirant
Thank you, for your prompt response. I have been reading the stats on device reliability, and I think 10TB is still too "new" to be using. I might just go with the 8TB to be on the safe side.
I'll let you know if I find something new on the 10TB drive compatibility with the RN214.
Hello
I shall do the same if I find anything new about the Red 10TB Compatibility.
Thanks
Kevin
