kncowans
Apr 14, 2018Virtuoso
Readynas 214 compatible with the WD Red 10TB HDD?
Hello all I am looking to upgrade the storage in my RN214 which currently has WD RED 5TB HDDs. I was looking at the WD RED 8TB HDD but noticed there is now a 10TB RED, however the 10TB RED is...
kncowans
Jun 01, 2018Virtuoso
Hello
Unfortunately I have not been able to find any answer to this question.
I have decided to hold off on upgrading my HDD until I can get a clear answer.
Sorry I could not of more help.
Kevin
n0Ob
Jun 01, 2018Aspirant
Thank you, for your prompt response. I have been reading the stats on device reliability, and I think 10TB is still too "new" to be using. I might just go with the 8TB to be on the safe side.
I'll let you know if I find something new on the 10TB drive compatibility with the RN214.
- kncowansJun 01, 2018Virtuoso
Hello
I shall do the same if I find anything new about the Red 10TB Compatibility.
Thanks
Kevin
- Marc_VJun 03, 2018NETGEAR Employee Retired
Strict tests is always done on different HDD brands and models and not all models are always listed on the HCL but as you have mentioned the 10TB reds is within the same family with the 8TB (WD80EFZX) so by that it should work with the RN214 unit you have.
The ReadyNAS HCL might have models not listed but it's more of a list of suggested drives rather than compatible only drives. The warning I would agree should be revised. but the 10TB reds would be working fine with it, 10TB Gold is actually listed.
Hope this helps!
Regards
- Marc_VJun 06, 2018NETGEAR Employee Retired
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- n0ObJun 21, 2018Aspirant
Hey Kevin - FYI, I just bought the 10TB WD Red 5400 drive. I'll try it out over the weekend and let you (and everyone) know if it works on the ReadyNAS 214. Let me know if you tried it already.
- n0ObJul 23, 2018Aspirant
Hi Kevin - I have validated that the 10TB drive (WD Red 5400) works on the ReadyNAS 214. It should up as 9.09TB available.
- kncowansJul 24, 2018Virtuoso
Hello
Thanks for taking the time to test thiis, i am sure it will help many people as it has me.
Kevin
