error404
Jun 10, 2020Aspirant
ReadyNAS 214 Door
hi guys. I am looking to remove the front door from my 214. Anyone have details how I achieve this. Thanks
Sandshark
Jun 11, 2020Sensei
Since the door forms a part of the cooling airflow design, why would you want to change that? Are you observing cooling issues that leaving the door open solved?
error404
Jun 11, 2020Aspirant
Hi Sandshark
The position of my 214 is abit restricted to the sides, plus it is the only position I can use it,
I do find with the door open the airflow seems to be better.
Kind regards
