MathemAddicts
Nov 08, 2015Tutor
ReadyNAS 214 or 316
I am looking at the 214 or 316 models for home use. My wife is a photographer, so we need a lot of storage. I will be using Raid 1, so 24 TB = 12 useable TB. I will also be using this like DropBox...
MathemAddicts
Nov 09, 2015Tutor
I actually use a separate HTPC. Will I still need the NAS to transcode?
Nov 09, 2015Guru - Experienced User
How are you accessing the media? DLNA, NFS, SMB, ???
If DLNA, what server are you using now? Plex?
- MathemAddictsNov 09, 2015Tutor
Right now the media is on the SSD in the HTPC. I do not store a ton of media, so I may not use the NAS for media at all; however, if I do, could I map it as a network drive and store videos from, say XBox Video app (in Windows 8) and shows DVR'd from Windows Media Center? Would I still need the NAS to transcode or, since they are being played through the relevant app in Windows 8 on my HTPC, am I okay with transcoding on the NAS?
- StephenBNov 09, 2015Guru - Experienced User
If you are access the media via a mapped drive (or directly from the share using NFS or SMB) then you don't transcoding. All the NAS is doing is hosting the file.
PLEX is more complicated. It streams to browsers, mobile devices, and some players - both locally and over the internet. Transcoding is quite important with Plex - sometimes because the player doesn't support codecs or media container, and sometimes because the network connection isn't fast enough to carry the media w/o transcoding. The RN316 will transcode 720p - not sure about 1080p, but I've heard that might stutter.
Anyway, I'd say the RN316 is a better choice for you (esp. given the small price gap at the moment). Having unused bays for future expansion is always good (it is most cost effective to expand into an empty bay).
- HeatherABCNov 10, 2015Apprentice
Won't the transcoding only come into play on Plex when you are using the NAS as the Plex server? I don't have any media mapped to my Plex server from my new NAS but will eventually be storing all of it on the NAS so haven't tried it yet. I was hoping the computer that's running my server would be the device doing the transcoding... am I wrong?
