Adam2696
Jul 17, 2021Aspirant
Readynas 214 shut Down for high temp
Just wondering what would cause my HD temps to rise. My Nas shut down due to all of the HD reporting too high if temp. This happened when i was not home but AC was on. Unsure of room temp but s...
Jul 17, 2021Guru - Experienced User
What are your typical disk temps?
Any possibility of a brownout?
- Adam2696Jul 17, 2021Aspirant
39c/102f
42c/107f
40c/104f
These are pretty typical. These are what it has been running all day, since i rebooted. Fan is set on cool, so constantly running fast.
Are these good usual temps.
Nothing should have been using the drives at the time they stopped.
Brownouts could be a possibility but noone in the house noticed anything.
- Adam2696Aug 18, 2021Aspirant
StephenB So after a couple of weeks, i got the idea of what is causing the issue. it seems to be immediately after the defrag completes (not sure why I posted nothing was using drives above, I guess I forgot). It also appears that all the disk drives get too hot. Originally I had a scheduled rclone doing something at 2 on wednesdays, but I moved that to thursdays. The problem stayed on Wednesday.
- SandsharkAug 18, 2021Sensei
Why are you defragmenting so often? Frankly, I don't defrag my NAS at all. Its effect on a RAID volume is far less than on a single drive, especially when using COW, and it's not like I execute programs from it or it contains a swap file used externally.
