firolver's avatar
firolver
ReadyNAS 214 Substitute
After seven solid years of service my ReadyNAS 214 appears to have bitten the dust. Might be a power supply or a mobo but tried it plugged into a few outlets and the device won't start - no lights, no fan, nada.
I have 4 2TB drives in the device that I suspect are still good. Is there another NAS that would accept these and retain the data? Do I have any chance of resurrecting the data on the drives?
Thanks for any help or advice.
1 Reply
  • StephenB's avatar
    It could just be the power adapter.  I suggest doing a risk-buy of a compatible adapter, and see if that brings it back to life.  You'll find several advertised on Amazon and other sites for around $25 USD.
    The disks can be migrated to any other ReadyNAS running OS-6. With some effort you can also migrate them to an older ReadyNAS Ultra or ReadyNAS Pro.
    You can alternatively connect the disks to a PC running linux, and manually assemble and mount the volume.
ProSupport for Business
