Leventh
Dec 20, 2019Apprentice
ReadyNAS 214 Tier Configuration
Dear All, I am new to forum, so I have had new ReadyNAS 214 four bay and did not setup yet. I am planning to configure it 3x2TB WD NAS Hard Drive using FlexRAID 0, but i need to know about tier setu...
- Dec 20, 2019
Personally I think a better plan would be to use two larger mechanical disks in RAID-1 (at 2x6 TB), and then use a pair of SSDs.
It'd be risky to use a single SSD for metadata tiering. It's not a cache, so if the disk fails you could lose your volume. I'm not sure if you can only do data tiering, or if data tiering includes metadata tiering. But even data tiering is described as "mostly temporary". https://kb.netgear.com/000060806/ReadyNAS-OS-6-10-Data-Tiering
But if you are also using RAID-0 for the mechanical disk, I guess you are already giving up on RAID redundancy.
As far as size goes, I suggest setting up the NAS w/o the SSD first, and see if the performance is ok for you. That would also give some more info on the amount of metadata your volume uses.
Personally I am ok w/o it on my RN526x. The data tiering won't help with large file speeds (which is limited by the network). Metadata tiering would be helpful for browsing large folders.
Dec 20, 2019Guru - Experienced User
Leventh
Thanks StephenB,
so i have just 3x2TB HDD nothing more, as my understanding it is risky and not worth to setup like this tier thing,
I am thinking to setup raid 0 directly :-) old fashion way.
