iamjaysin
Mar 25, 2023Follower
ReadyNAS 2304 boots to blank screen
I have an old ReadyNAS 2304 that can get to the bios and will boot up per the picture below then goes to a blank screen then this picture again then to a blank screen. No errors or anything, tried all the boot options via reset button and still after factory reset/os install still the same thing.
Not sure what to do from here, any help would be appreciated.
1 Reply
- SandsharkSensei
Does it show up at all in RAIDar? If so, what status does it show? Can you get to the reset button "menu" (How-do-I-access-the-boot-menu-on-my-ReadyNAS-2304-3130-or-3138-storage-system)? Do you have drives installed?
You may need to do a USB recovery, but best not to jump straight to that.
