BR0KK
Aug 05, 2020Aspirant
ReadyNAS 2304 data Recovery on machine?
Hi, one of my customes uses a RN 2304 with 2x 4 TB in X-RAID. Everything works fine (no errors or downtime so far) but today i was asked to retrieve an defective *.xlsx file from that nas. The...
- Aug 06, 2020
The underlying operating system is Debian Jessie. Yes, you can SSH into the unit. It has to be enabled on the Settings screen of the GUI, then you log in as user root using the NAS admin password. Note that since you are root, you can do things you shouldn't. The warning you get when you enable SSH is based on that -- Netgear will not help you out of a mess you created yourself via SSH. They will not automatically deny support because it is enabled.
With the BTRFS file system that the NAS uses, a lot of undelete tools won't work, and I think what you need to do is recover a delected old version. Here is one that claims it does, though I have no experience with it: btrfs-undelete on GitHub. If Copy on Write is enbled, that may help things out.
Have you tried workbook repair (Repairing-a-corrupted-workbook )? It's probably best to work on a local copy, not the original. There are some other recovery tools for Excel around, too.
BR0KK
Aug 10, 2020Aspirant
Yeah i will probalby try a lot of different things before i'll ssh into a NAS (with an unknown setup and my not so great linux skills :))
ReClaimMe is a windows only program taht needs access to all disks via SATA or an adapter.
The btrfs tools look facinating but.... i'm not trying this on a running customer system with data on it :D
1. Order of business is to activate the snapshot function
The nas is built on 2x 4tb Disks. How much space will those snapshots take away from the shares?
thx :)
Aug 10, 2020Guru - Experienced User
It really depends on the usage. When a snapshot is first taken, it takes no space - all the files are shared between the snapshot and the main share. As files are deleted, moved, and rewritten the space needed by the snapshot goes up. (Adding files doesn't increase the snapshot space though).
If the customer does have live databases on the NAS, then it is best not to enable snapshots on the shares holding the databases. The reason is that the database will become fragmented fairly quickly.
What I suggest doing is enabling custom snapshots, which gives you explicit control over retention. Then you can adjust the retention to get the right balance between snapshot usage and disk space. Note you will want to enable quota on the volume settings - otherwise you won't get much information on how much space the snapshots are taking.
Here are the settings that I use myself (on a home NAS). The schedule gives me daily snapshots, if you don't schedule you should get hourly snapshots (but only when the share has changed). In my case, these settings add less than 5% to my overall space usage. But a business NAS would have a very different workload.
BR0KK wrote:
ReClaimMe is a windows only program that needs access to all disks via SATA or an adapter.
Only one disk in your case. since you are running RAID-1 (mirrored disks). Though you'd want to power down the NAS before you remove the drive (and leave it powered down until you reinsert it). Otherwise you will need to do a RAID resync when you put the disk back.
It is fairly expensive, though of course you could use it for other customers. Not sure how well it handles getting a previous version of a file though - it's main application is RAID recovery.
