sully8391
Sep 01, 2020Aspirant
ReadyNAS 2304 fails to remove VLAN
Simple as that. I click the gear icon, select delete, confirm, and I get the message "Failed to remove VLAN" with code 4004020001. No explantion of why or how to resolve the issue. Any ideas?
sully8391
Sep 07, 2020Aspirant
Hey. I'm running OS 6.10.1
Sep 08, 2020Guru - Experienced User
Ok. There were some bugs similar to this in earlier firmware, but AFAIK they were fixed before 6.10.1.
One thing you could try is to do an OS reinstall. That should reset your network connection to factory default settings (DHCP, no bonding). It will also reset your admin password to password and disable volume quota (which you can reset on the volume settings wheel). It shouldn't affect your data, or other configuration settings.
Instructions are on pages 26-28 here: https://www.downloads.netgear.com/files/GDC/RN2120/ReadyNAS_OS6_Rackmount_HWM_EN.pdf Just be careful not to do the factory default by mistake, as that will destroy your data and configuration.
