Jeffery_S's avatar
Jeffery_S
ReadyNAS 2304 very slow resyncing and log question
Couldn't find my model in the Model drop down list. It's a ReadyNAS 2304, just received it yesterday. I put in 4 - 4TB Seagate drives in it and it's been resyscing all night. With 4 - 4TB drives how long should a resyncing take with 19mb of data? It's been going for maybe 8 hours now.
Secondly I have all these entries in the log. Is this typical.
Sep 24, 2019 12:33:48 PM System: ReadyNASOS background service started.
Sep 24, 2019 12:33:45 PM Volume: Resyncing started for Volume VOL1.
Sep 24, 2019 12:33:43 PM System: ReadyNASOS service or process was restarted.
Sep 24, 2019 10:34:54 AM System: ReadyNASOS background service started.
Sep 24, 2019 10:34:51 AM Volume: Resyncing started for Volume VOL1.
Sep 24, 2019 10:34:49 AM System: ReadyNASOS service or process was restarted.
Sep 24, 2019 09:11:00 AM System: ReadyNASOS background service started.
Sep 24, 2019 09:10:57 AM Volume: Resyncing started for Volume VOL1.
Sep 24, 2019 09:10:55 AM System: ReadyNASOS service or process was restarted.
Sep 24, 2019 07:36:33 AM System: ReadyNASOS background service started.
Sep 24, 2019 07:36:30 AM Volume: Resyncing started for Volume VOL1.
Sep 24, 2019 07:36:28 AM System: ReadyNASOS service or process was restarted.
Sep 24, 2019 05:52:57 AM System: ReadyNASOS background service started.
Sep 24, 2019 05:52:54 AM Volume: Resyncing started for Volume VOL1.
Sep 24, 2019 05:52:52 AM System: ReadyNASOS service or process was restarted.
Sep 24, 2019 04:38:57 AM System: ReadyNASOS background service started.
Sep 24, 2019 04:38:55 AM Volume: Resyncing started for Volume VOL1.
Sep 24, 2019 04:38:51 AM System: ReadyNASOS service or process was restarted.
Sep 24, 2019 03:29:30 AM System: ReadyNASOS background service started.
Sep 24, 2019 03:29:28 AM Volume: Resyncing started for Volume VOL1.
Sep 24, 2019 03:29:26 AM System: ReadyNASOS service or process was restarted.
Sep 24, 2019 02:24:04 AM System: ReadyNASOS background service started.
Sep 24, 2019 02:24:02 AM Volume: Resyncing started for Volume VOL1.
Sep 24, 2019 02:24:01 AM System: ReadyNASOS service or process was restarted.
Sep 24, 2019 01:19:58 AM System: ReadyNASOS background service started.
Sep 24, 2019 01:19:55 AM Volume: Resyncing started for Volume VOL1.
Sep 24, 2019 01:19:54 AM System: ReadyNASOS service or process was restarted.
Sep 24, 2019 12:22:22 AM System: ReadyNASOS background service started.
Sep 24, 2019 12:22:21 AM Volume: Resyncing started for Volume VOL1.
Sep 24, 2019 12:22:19 AM System: ReadyNASOS service or process was restarted.
Sep 23, 2019 10:43:28 PM System: ReadyNASOS background service started.
Sep 23, 2019 10:43:26 PM Volume: Resyncing started for Volume VOL1.
Sep 23, 2019 10:43:24 PM System: ReadyNASOS service or process was restarted.
Sep 23, 2019 09:52:50 PM System: A hotfix was applied to your system (6.9.5 Hotfix 1).
Sep 23, 2019 09:50:07 PM System: ReadyNASOS background service started.
Sep 23, 2019 09:50:07 PM System: Firmware was upgraded to 6.9.5.
Sep 23, 2019 09:50:05 PM Volume: Resyncing started for Volume VOL1.
Sep 23, 2019 09:47:00 PM System: The system is rebooting.
The reboot was from firmware upgrade but why all the "ReadyNASOS service or process was restarted." then Resyncing?
Any help would be most appreciated.
Thanks,
Jeffery
  • StephenB's avatar
    It's resyncing 12 TB in order to build the RAID array.  It doesn't matter that the file system is empty (free space needs to be synced too).
    So it will normally take a while.
    Jeffery_S wrote:
    Secondly I have all these entries in the log. Is this typical. ...
    This is not typical, so something isn't going right.
    If you are the original purchaser of this NAS, you are entitled to phone support (via my.netgear.com).  I suggest you contact them.
    • Jeffery_S's avatar
      Jeffery_S
      Thanks a lot for your reply.
      I've only owned a two drive ReadyNAS so wasn't sure on that, but that does make sense on the sync.
      I'll contact Netgear about the log, it did't look right to me but wanted to check.
      Thanks,
      Jeffery
ProSupport for Business
