asaabey
Jan 12, 2019Aspirant
ReadyNAS 2tb x 6 at RAID-5 having a capacity of RAID-10 config
My ReadyNAS 316 was initially set up with 3 x 2Tb drives. Subsequently, I added another 3 x 2Tb drives hoping to achieve a capacity of 9.06 Tb as estimated by the RAID calculator at https...
asaabey
Jan 17, 2019Aspirant
StephenB replied
Note the data volume array is RAID-5, and is about 10 GB - so the RAID is correct.
The problem is that the BTRFS file system hasn't expanded to use all the space.
If you have good linux skills you could try expanding the file system yourself.
Thank you StephenB. Expanding btrfs manually, fixed the problem.
