marius_roma
Jan 28, 2013Aspirant
ReadyNAS 3100 - Enlarging disks
I have a ReadyNAS 3100 with 4 2 TB HD in RAID 5. I was told I can replace the 2 TB HD with 3 TB HDs. Is it correct? Where can I locate a list of 3TB HDs suitable to be used with the ReadyNAS3100? ...
marius_roma
StephenB wrote: There is an 8 TiB growth limit. Do you know what disks were installed on the original install (or the last factory limit). You can't grow more than 8 TiB from the initial volume size.
Thank you for the message and the information.
Do you mean that if I replace the 4 existing 2TB disks (8 TB raw disk space corresponding to about 5,4 TB available disk space in RAID) with 4 3 TB disks I will have anyway 8 TB raw disk space corresponding to about 5,4 TB available disk space?
Regards
marius
