marius_roma
Jan 28, 2013Aspirant
ReadyNAS 3100 - Enlarging disks
I have a ReadyNAS 3100 with 4 2 TB HD in RAID 5. I was told I can replace the 2 TB HD with 3 TB HDs. Is it correct? Where can I locate a list of 3TB HDs suitable to be used with the ReadyNAS3100? ...
Jan 28, 2013Guru - Experienced User
No. I mean that if you started with a volume size of X TiB then you can't expand it beyond X+8 TiB. This is unlikely to be an issue for in your case. But it is possible (for instance if you started with 2x1TB) , so I mentioned it.
