marius_roma
Jan 28, 2013Aspirant
ReadyNAS 3100 - Enlarging disks
I have a ReadyNAS 3100 with 4 2 TB HD in RAID 5. I was told I can replace the 2 TB HD with 3 TB HDs. Is it correct? Where can I locate a list of 3TB HDs suitable to be used with the ReadyNAS3100? ...
marius_roma
Than k you again.
So, given the raw sum of my HDs is now 8 TB, my upper limit will be 8+8 TB = 16 TB, is it correct?
Regards
marius
Regards
marius
