ChrisB2021
Nov 29, 2021Aspirant
Readynas 312 - bricked after firmware update attempt
Hello, I attempted a firmware update of my readynas 312 to latest version (6.10.6) from a few major versions (6.5.x I think), using the admin portal. Left it overnight and came back to system that ...
J_Malmlund
Nov 30, 2021Tutor
Hi,
Not that this might help much but out of pure interest... You said "you think"?! you tried to update from 6.5.x??
In the release notes for the new ReadyNAS OS V6.10.x versions there is this warning:
"systems must not be updated directly to 6.10.x from 6.3.x or older firmware. They must first be updated to either 6.2.5 or 6.3.5 then to 6.5.2 and then to 6.10.x."
If you're not sure from what version you tried to do the system update, you might very well have bricked your unit in a very hard to recover way.
I'm not familiar with your model of NAS but I'd start by looking into how to do initiate a reinstall of the system from the built in usb storage that manages and sets up the NAS the first time you boot it up with new and empty disks. I did it once back in the os 4.x.x days (ReadyNAS PRO-6) and while I had to redo quite a bit of configuration it did get the my box back up with a working system after a failed system update.
With that being said, I do sincerly hope someone else might shed some more insights into what can be done because I'm out of ideas for now.
ChrisB2021
Nov 30, 2021Aspirant
Thanks for the reply.
I had not connected the NAS on my network in a while (1-2 years) due to relocation and so I didn’t even think about issues with firmware versions! I left it to upgrade overnight and I first noticed a problem when I couldn’t ping the box.
Anyway, I’ve tried all manners of USB drive firmware reinstalls and not having much luck.
