chris_modica
Mar 26, 2020Aspirant
ReadyNAS 312 - NIC Failure - How to Recover Data on the NAS??
Hello, I was wondering if anyone can help me with this. I am remotely supporting a customer office which uses a pair of ReadyNAS 312. Recently they lost access to the NAS. We found that we cannot...
- Apr 08, 2020
Thanks for following up!
chris_modica
Thanks for your reply.
The NAS we used were the same model and firmware, and we tried moving the HDDs from the original NAS#1 to the recovery NAS#2 first without factory defaulting, and then when that wasn't successfull we tried the factory default on NAS#2, but that didn't work either (of course we performed the factory default on NAS#2 before we moved the NAS#1 HDDs to it).
The NAS#2 started up after the HDD swap, but it seemed as though some setting was left on the NAS#1 HDD that stopped us accessing NAS#2 through the GUI. Not sure.
We are planning to work on the data recovery more next week. I will try this again, maybe it will just take some fiddling to make it work. If not, I will install mdadm and btrfs and try that.
Thanks for your advice, I appreciate it.
Mar 27, 2020Guru - Experienced User
You definitely can migrate disks between OS-6 platforms. I've done it (though not recently).
Was NAS#1 on the same IP subnet as NAS#2? Did you try RAIDar to see if it could find it?
- chris_modicaApr 07, 2020Aspirant
We were able to successfully migrate the HDDs to another RN312.
The cause of our difficulties the first time was, after accessing via Raidar we did some intial setup, setting the original IP address, etc., in the setup wizard that opens automatically. That made it inaccessible though.
When we tried again and cancelled the setup wizard in Raidar, we were able to access it no problem.
Thanks again for your support.
- StephenBApr 08, 2020Guru - Experienced User
