schnax
Jun 25, 2015Apprentice
Readynas 312 or 314
Hi, considering either the 312 or 314 for our office to share files. Beside the different of how much storage each one can provide is there a difference in performance if you have 2 or 4 disks? O...
Nhellie
Jun 25, 2015Virtuoso
Performance should be the same since they are using the same CPU model. Both can handle 25-50 concurrent users. You can compare them here.
http://www.netgear.com/business/product ... -techspecs
