schnax
Jun 25, 2015Apprentice
Readynas 312 or 314
Hi, considering either the 312 or 314 for our office to share files. Beside the different of how much storage each one can provide is there a difference in performance if you have 2 or 4 disks? O...
Jun 25, 2015Guru - Experienced User
The RN314 has a LCD front panel, which makes it a bit easier to navigate the boot menu options.
If your budget stretches to the 314 I'd go for it, and populate it initially with 2 disks. It's cheaper to expand if you have empty slots to work with.
