pastorbrady
Jan 29, 2018Aspirant
ReadyNAS 312 won't finish is re-install
We had to fire an employee on short notice, he set it up so I don't have the password. Tried to do an OS Re-install but when checking it on RAIDar it's stuck at checking file systems for about an h...
bedlam1
Jan 29, 2018Prodigy
Can't you access the Admin Page using Raidar?
Then use logon: admin Password: password
- pastorbradyJan 29, 2018Aspirant
I tried that but it didn't work, I believe he set one up and we can no longer access it ;/
- bedlam1Jan 29, 2018Prodigy
IF you have successfuly performed an OS Re-install that will have set the login to what I showed above
Maybe another reboot may help
When I try that it gets stuck at "Checking system files..."
