pastorbrady
Jan 29, 2018Aspirant
ReadyNAS 312 won't finish is re-install
We had to fire an employee on short notice, he set it up so I don't have the password. Tried to do an OS Re-install but when checking it on RAIDar it's stuck at checking file systems for about an h...
pastorbrady
I tried that but it didn't work, I believe he set one up and we can no longer access it ;/
bedlam1
Jan 29, 2018Prodigy
IF you have successfuly performed an OS Re-install that will have set the login to what I showed above
Maybe another reboot may help
- pastorbradyJan 29, 2018Aspirant
When I try that it gets stuck at "Checking system files..."
