jbogdanovich
Jun 06, 2022Aspirant
ReadyNAS 3138 IP/DNS settings can't be modified
I have a ReadyNAS running 6.10.7 which was recently upgraded from 6.10.6 (same problem on 6-10-6). The two domain controllers which run DNS services on my domain are being retired so I need to chang...
Marc_V
Jun 06, 2022NETGEAR Employee Retired
@jbofgdanovich
Welcome to the Community!
Have you tried applying the settings again after doing it the first time? readynasd should overwrite the config but there are times that the procedure might not apply right away. You may try applying it again or saving the config again once you have done it the first time.
Not really sure if it's a bug but this will be reported. Please let me know if the workaround did the trick.
HTH
- jbogdanovichJun 06, 2022Aspirant
I'm not sure I follow your suggestion to Apply the settings again. Once I add, delete or change a DNS setting on the bonded eth0 & eth1 (bond0), I apply and get the spinning wheel. It then returns to the parent menu GUI. I click back on the gear to edit and see the original DNS settings again. I can try changing the same way 10 times and it doesn't stick.
I just tried directly modifying the /etc/resolv.conf file. When I go into the GUI to check, it hasn't changed to the new IPs. I reboot the NAS and the old DNS IPs overwrite the resolv.conf. Just as I guessed earlier, the DNS setting for bond0 seem to be stored somewhere else. Where?
I have Support Case #-------- with and extended warranty contract so it's already reported. They just don't respond for over 3 weeks now. How can you help?
Thanks
Jan
- Marc_VJun 06, 2022NETGEAR Employee Retired
Let me check on the case, let's see what we can do. Thanks for providing additional information. Please make sure updated logs are attached on the case. Also they may request access.
- jbogdanovichJun 09, 2022Aspirant
Still no contact from anyone at Netgear support. I am a Powershift Business Partner with a support contract.
