r32nj
Nov 11, 2019Tutor
How to modify audit settings on OS 6.10.2
I recently enabled the AUDIT function on my ReadyNAS. It is generating a huge # of entries (I turned everything on). I don't see any option on the AUDIT screen to turn it off or modify the original parameters.
How do I make changes to the AUDIT setup?
r32nj wrote:
What you suggested was what I followed to turn ON auditing in the first place. Now how do I turn it off or modify the initial settings (as I am getting way to many entries with everything turned on)?
There are some settings for Audit in System->settings->services->audit that you can change.
- Marc_VNETGEAR Employee Retired
You have to go to System>Logs and choose the Audit label on the left side. Auditing should be enabled first
Once enabled, the settings options should appear and you should be able to modify.
Please see http://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf on page 247
HTH
Regards
- r32njTutor
