DavidCas
Jun 28, 2022Guide
ReadyNAS 3138 Warranty
My ReadyNAS 3138 is no longer booting. When power is applied, drive 1 LED off, drives 2 & 3 LED green, drive 4 LED red, no status LEDs, fans spinning. I removed the drives, apply power, no status LE...
Jun 28, 2022Guru - Experienced User
Did you follow this guide:
DavidCas
Jun 28, 2022Guide
Yes, I did. I've tried following those steps several times. When I hit submit, the system returns a 500 error saying that they have an issue on their end. But, it's been doing that since Friday. I was hoping others could confirm that it is an actual server error, and not an error based on my warranty end date.
- Marc_VJun 28, 2022NETGEAR Employee Retired
Please send an E-mail to [email protected] this will create a case automatically and be sent to ReadyNAS Support and have your warranty and issue checked. Please provide me the case number as well if possible.
HTH
- DavidCasJun 30, 2022Guide
I've attached the document from when we purchased the device.
- Marc_VJun 30, 2022NETGEAR Employee Retired
I have downloaded and forwarded the file, I also removed it on the post. Kindly attached it to the case by attaching it to the email.
Many thanks
- DavidCasJul 15, 2022Guide
I just got asked if I wanted to close my case. I'm not sure why. Nothing has been done yet. Do they close the case to move it to another level of support?
