AndyBee1
May 08, 2014Aspirant
ReadyNAS 314 - a year of hell and now lost 10years of data!
I bought a ReadyNAS 314 when they were new in the market back in April 2013. I bought it partly because I wanted to safeguard my increasing data storage with redundancy in case of disk failure, and al...
AndyBee1
May 13, 2014Aspirant
Disk 4 seems to be cloning ok - well it has definitely been running for a lot longer than disk 2 managed, and there's only the infrequent clickedy-click coming from it.
Here's the status at the moment:
Is this good, bad, gonna take much longer?
What goes up and when? is 513GB of errors going to go downwards as it recovers stuff, do I need to run the other 11 commands that dorp the skip size down and do it in reverse? (that's another 11 runs through!) Does it get quicker on each pass as it only has to try the bad parts? Do I have to many to make it worthwhile? etc...
Here's what is currently still running from this morning:
Here's what is left to run!:
If someone could give me a quick run-down of the process and what I would see in numbers that would be great.
GNU ddrescue 1.16
Press Ctrl-C to interrupt
rescued: 13600 MB, errsize: 513 GB, current rate: 0 B/s
ipos: 442674 MB, errors: 841, average rate: 447 kB/s
opos: 442674 MB, time since last successful read: 11 s
Copying non-tried blocks...
ddrescue -r 1 -a 10485760 -b 4096 -d -f -K 65536 /dev/sdb /dev/sdc /mnt/hdd0/btrfsd4log.txt (sector size=4096, forced, min readrate=10485760, skip size=65536, retries=1)
ddrescue -R -r 1 -a 10485760 -b 4096 -d -f -K 65536 /dev/sdb /dev/sdc /mnt/hdd0/btrfsd4log.txt (and again in reverse)
ddrescue -r 1 -a 10485760 -b 4096 -d -f -K 16384 /dev/sdb /dev/sdc /mnt/hdd0/btrfsd4log.txt (skip size down to 16384)
ddrescue -R -r 1 -a 10485760 -b 4096 -d -f -K 16384 /dev/sdb /dev/sdc /mnt/hdd0/btrfsd4log.txt (and again in reverse)
ddrescue -r 1 -a 10485760 -b 4096 -d -f -K -A 4096 /dev/sdb /dev/sdc /mnt/hdd0/btrfsd4log.txt (skip size down to 4096, retry all failed/skipped sections)
ddrescue -R -r 1 -a 10485760 -b 4096 -d -f -K -A 4096 /dev/sdb /dev/sdc /mnt/hdd0/btrfsd4log.txt (and again in reverse)
ddrescue -r 1 -b -d -f -K 1024 /dev/sdb /dev/sdc /mnt/hdd0/btrfsd4log.txt (skip size down to 1024, no min readrate)
ddrescue -R -r 1 -b -d -f -K 1024 /dev/sdb /dev/sdc /mnt/hdd0/btrfsd4log.txt (and again in reverse)
ddrescue -r 1 -b -d -f -K 256 /dev/sdb /dev/sdc /mnt/hdd0/btrfsd4log.txt (skip size down to 256)
ddrescue -R -r 1 -b -d -f -K 256 /dev/sdb /dev/sdc /mnt/hdd0/btrfsd4log.txt (and again in reverse)
ddrescue -r 1 -b -d -f -K 64 /dev/sdb /dev/sdc /mnt/hdd0/btrfsd4log.txt (skip size down to 64)
ddrescue -R -r 1 -b -d -f -K 64 /dev/sdb /dev/sdc /mnt/hdd0/btrfsd4log.txt (and again in reverse)
