AndyBee1
May 08, 2014Aspirant
ReadyNAS 314 - a year of hell and now lost 10years of data!
I bought a ReadyNAS 314 when they were new in the market back in April 2013. I bought it partly because I wanted to safeguard my increasing data storage with redundancy in case of disk failure, and al...
Aug 22, 2014Guru - Experienced User
Though he did get gigabit with the third cable, which is puzzling.
mangrove wrote: That two cables would be bad is amazingly unlikely. The theory that the capacitors in the switch are bad (a switch known for its bad capacitors) is much more likely. Check what speeds you actually get when copying.
I think I'd let well enough alone, but keep an eye on the link speed. If the problem happens again then I'd replace the switch - unmanaged gigabit switches aren't expensive.
