AndyBee1
May 08, 2014Aspirant
ReadyNAS 314 - a year of hell and now lost 10years of data!
I bought a ReadyNAS 314 when they were new in the market back in April 2013. I bought it partly because I wanted to safeguard my increasing data storage with redundancy in case of disk failure, and al...
mdgm-ntgr
Aug 25, 2014NETGEAR Employee Retired
CAT5e is better than CAT5. Some higher quality CAT5 cables will work better than lower quality ones but to be sure it should work well with gigabit you need CAT5e or newer. CAT6 is a good option too.
For any CAT standard some cables will be higher quality than others. Some cables will exceed the minimum spec.
