Rgibbfan
Jan 22, 2020Aspirant
ReadyNas 314 - Inactive Volumes
Good afternoon, I have a ReadyNas 314 which lost a drive yesterday and then hung while synchronising to the replacement drive. It was not showing any signs of life ofter 9 hours so we pulled the ...
- Jan 22, 2020
Welcome to the Community!
Do you still have Hardware Warranty? You may want to go to "My Support and Click on Contact Support button and then proceed with "Get answers about NETGEAR products before I buy". It will then ask you to contact Support through Chat or call.
You will have to provide the Serial number of your NAS to the expert so they can pull up your product and purchase a Pay-Per-Incident Support.
If in any case you are still having issues with the said steps, please send me in PM the case number created.
HTH
Regards
Marc_V
Jan 22, 2020NETGEAR Employee Retired
HTH
Regards
Rgibbfan
Hi Marc,
Thanks for comming back to me. No, there is no hardware warrenty on it unfortunatly. Do Netgear offer a one off support cost to cover such situations?
Many thanks
Paul
- StephenBJan 23, 2020Guru - Experienced User
They do, and I think the mods (either Marc_V or JohnCM_S ) can help facilitate gettting it. Cost should be less than $100USD. It is only available if you are the original purchaser - Netgear won't provide support for used equipment.
If the volume is just slightly out-of-sync, Netgear should be able to remount it with per-incident support. But if there is file system corruption due to lost writes, then you would need a data recovery contract. https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service
If you can connect all the disks to a Windows PC, you could alternatively use ReclaiMe software to extract the data.
