Rajema
Dec 11, 2019Aspirant
ReadyNas 314 boot stopped to 93%
Hi, The readynas won't finish the boot process. It blocked on 93% and it show upnphttpd.service on the Screen display. I preview to reinstall the firmware but i want to know if someone have already...
- Jan 07, 2020
OS reinstall via Boot Menu solved the problem. Thank you
Rajema
Dec 12, 2019Aspirant
I can download the log file. It have been send to you via PM
But there is the result from Diagnostic on Raidar
Successfully completed diagnostics
System
No errors found.
Logs
No errors found.
System Management
2019-12-12 08:05:21: DB (main) schema version: 24 ==> 24
2019-12-12 08:05:21: DB (queue) schema version: new ==> 0
2019-12-12 08:05:21: Failed to INSERT INTO service_cifs
2019-12-12 08:05:21: rndb_import() ==> 1 (257ms)
2019-12-12 08:05:21: Error rndb_import() ==> rc=1
2019-12-12 08:05:21: dba import failed
2019-12-12 08:05:21: Failed to start ReadyNAS System Daemon.
2019-12-12 08:05:20: DB (main) schema version: 24 ==> 24
2019-12-12 08:05:20: DB (queue) schema version: new ==> 0
2019-12-12 08:05:20: Failed to INSERT INTO service_cifs
2019-12-12 08:05:20: rndb_import() ==> 1 (208ms)
2019-12-12 08:05:20: Error rndb_import() ==> rc=1
2019-12-12 08:05:20: dba import failed
2019-12-12 08:05:20: Failed to start ReadyNAS System Daemon.
2019-12-12 08:05:19: DB (main) schema version: 24 ==> 24
2019-12-12 08:05:19: DB (queue) schema version: new ==> 0
2019-12-12 08:05:19: Failed to INSERT INTO service_cifs
2019-12-12 08:05:19: rndb_import() ==> 1 (199ms)
2019-12-12 08:05:19: Error rndb_import() ==> rc=1
2019-12-12 08:05:19: dba import failed
2019-12-12 08:05:19: Failed to start ReadyNAS System Daemon.
2019-12-12 08:05:18: DB (main) schema version: 24 ==> 24
2019-12-12 08:05:18: DB (queue) schema version: new ==> 0
2019-12-12 08:05:18: Failed to INSERT INTO service_cifs
2019-12-12 08:05:18: rndb_import() ==> 1 (235ms)
2019-12-12 08:05:18: Error rndb_import() ==> rc=1
2019-12-12 08:05:18: dba import failed
2019-12-12 08:05:18: Failed to start ReadyNAS System Daemon
mdgm
Dec 13, 2019Virtuoso
Rajema wrote:2019-12-12 08:05:21: Failed to INSERT INTO service_cifs
That error I think from memory would suggest corruption of the main service configuration file. As it's corrupt the management service can't import expected values into the database.
If the 4GB root volume isn't overly full (can easily check that looking at e.g. btrfs.log) then simply replacing that configuration file with the default one or a working one from a backup should be enough to resolve the problem.
Re-installing the firmware wouldn't help with this problem.
