Ray2
Feb 10, 2019Luminary
ReadyNAS 314-Firmware 6.9.5 Antivirus?
Turned off the built-in antivirus on my ReadyNAS 314 some time back due to continuous and annoying false positives.
Not sure what version I was running when I turned it off---but now up to vers...
Ray2
Feb 11, 2019Luminary
Thank you for your observations. I will give it a try again and see what happens.
I will reply after a while to let readers know the results.
Ray2
I turned it back on and it still picking up about 30 old archived Word documents created in the late 90's in the Win95 days. It involves several different folders and each folder contains a variety of other files that aren't being picked up as infected--so that it is not the entire folder that it is picking up. Says it is a legacy Trojan. BUT I have checked not all, but an assortment of these files with two different anti-virus programs and malware bytes too and they come up clean.
I'm thinking of turning it off again unless anyone has a further thought, that does NOT include deleting the files, which I am loathe to do?
