loggin
Nov 18, 2022Aspirant
ReadyNAS 314 how to see resync status via ssh ?
Ok so mine is a tail of woe, a kodi reinstall lead to a library rescan and appears to have stirred the cobwebs on one of my disks and caused its demise, I woke up last saturday morning to a very unres...
Sandshark
Nov 18, 2022Sensei
Use the command watch cat /proc/mdstat for continuous updates, or leave out watch for a single update.
loggin
Cheers, it's only climbed 14% in the last 4 days then it appears, anyone know if adding a new disk before this completes would be problematic or would help speed things up ?
- StephenBNov 18, 2022Guru - Experienced User
loggin wrote:
Cheers, it's only climbed 14% in the last 4 days then it appears, anyone know if adding a new disk before this completes would be problematic or would help speed things up ?The resync needs to complete before the system will process another disk.
- SandsharkNov 19, 2022Sensei
So it's re-syncing with the bad drive? That could take a very long time, and likely will ultimately fail. Do you know which drive it is?
- StephenBNov 19, 2022Guru - Experienced User
Hard to say if a bad drive is being resynced, or if the system is trying to resync a good drive, with the bad drive slowing the process down.
You can try smartctl -x on each of the drives - that could help identify which one is causing the problem.
