whetsel's avatar
whetsel
ReadyNAS 314 incorrect consumed storage reporting
I have been moving some large files around and have tried running a balance but something is incorrect about my storage reporting in FrontView.   I have a ReadyNAS 314 running the latest firmware (...
  • StephenB's avatar
    Dec 18, 2023
    whetsel wrote:
    I may also try: (not sure /mnt is the correct location to run this against)
    btrfs balance start /mnt
    It's not.  Normally mount is an empty folder in root.
    No idea why the command did something to the data volume on Sandshark's system back in 2016.
    whetsel wrote:
    If this doesn't work, what the heck are my next steps?
    Obviously it would be prudent to have an up-to-date back up of the data.
    You should be using btrfs commands for your troubleshooting - the usual linux commands do not give the right answers for btrfs.
    btrfs fi show /data
    btrfs fi df /data
    You can check if you deleted all the snapshots using this:
    btrfs subvolume list -s /data
    This will also give more details
    btrfs fi du -s /data/sharename
    This last command can take a long time to complete. You can leave off the -s, but you will get a lot of output.
    Note also you can use it (with or without the -s) on subfolders of the share, or even individual files.
ProSupport for Business
