rraszews
Jan 04, 2015Aspirant
ReadyNAS 314 nfs issue
Hi, I've been pretty happy with my ReadyNAS since I got it a year ago, but in the past two weeks, everything suddenly started going up the spout. I got my RN314 preinstalled with four seagate 3T...
rraszews
I think you and I are having this same conversation on twitter. But for the sake of posterity:
I've lowered the NFS thread count to 2. I'm using a custom share with snapshots turned off and bit-rot protection turned on (At the time, I didn't know what it was. I don't have any objection to turning it off if that helps). I've just created a new share without bit-rot protection or snapshots and will try using that as my backup destination tonight to see what happens.
Since I'm using about 4.2 TB of space on the nas, local backups aren't really a practical option. When I started having trouble, I set up an offsite cloud backup job, but since I'm limited by residential FIOS speeds, it'll take a few weeks for that to catch up (My most critical data is already backed up, but I hadn't pulled the trigger on backing up my digital media because of the amount of it)
