rraszews
Jan 04, 2015Aspirant
ReadyNAS 314 nfs issue
Hi, I've been pretty happy with my ReadyNAS since I got it a year ago, but in the past two weeks, everything suddenly started going up the spout. I got my RN314 preinstalled with four seagate 3T...
rraszews
Jan 07, 2015Aspirant
Oh dear. The problem recurred this morning. Same message as before. It happened about 2 minutes into a large rsync onto the new share that doesn't have bit-rot protection. Since lots of computers on my network use the RN, I can't say for sure if anything else was going on at the same time, but there shouldn't have been any other scheduled tasks occuring then.
I'm going to reduce the amount of backing up I do for a while and see if there's a particular usage pattern that triggers the issue. Obviously, that's not a good long-term solution, but if I can't directly fix the problem, I at least have to have a workaround while I decide on a replacement.
