agustaf4
Jul 14, 2014Aspirant
ReadyNas 314 not working with Seagate Expansion 5tb usb
I have a 314 with a 4tb seagate external usb 3 drive plugged in which is working good, but I just plugged in on the other usb 3 a 5th external seagate drive and it shows under system the usb icon with...
agustaf4
The kernel log has this entry sdf1 is the 4tb which works fine sdg1 is the 5tb which is not working
Jul 14 16:25:07 readynas kernel: scsi 7:0:0:0: Direct-Access Seagate Backup+ Desk 050B PQ: 0 ANSI: 6
Jul 14 16:25:07 readynas kernel: sd 7:0:0:0: [sdf] 976754645 4096-byte logical blocks: (4.00 TB/3.63 TiB)
Jul 14 16:25:07 readynas kernel: sd 7:0:0:0: [sdf] Write Protect is off
Jul 14 16:25:07 readynas kernel: sd 7:0:0:0: [sdf] Mode Sense: 4f 00 00 00
Jul 14 16:25:07 readynas kernel: sd 7:0:0:0: Attached scsi generic sg5 type 0
Jul 14 16:25:07 readynas kernel: sd 7:0:0:0: [sdf] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jul 14 16:25:07 readynas kernel: sdf: sdf1
Jul 14 16:25:07 readynas kernel: sd 7:0:0:0: [sdf] Attached SCSI disk
Jul 14 16:25:07 readynas kernel: scsi 8:0:0:0: Direct-Access Seagate Expansion Desk 0739 PQ: 0 ANSI: 6
Jul 14 16:25:07 readynas kernel: sd 8:0:0:0: [sdg] 1220942645 4096-byte logical blocks: (5.00 TB/4.54 TiB)
Jul 14 16:25:07 readynas kernel: sd 8:0:0:0: [sdg] Write Protect is off
Jul 14 16:25:07 readynas kernel: sd 8:0:0:0: [sdg] Mode Sense: 2b 00 10 08
Jul 14 16:25:07 readynas kernel: sd 8:0:0:0: [sdg] Write cache: enabled, read cache: enabled, supports DPO and FUA
Jul 14 16:25:07 readynas kernel: sd 8:0:0:0: Attached scsi generic sg6 type 0
Jul 14 16:25:07 readynas kernel: sdg: sdg1
Jul 14 16:25:07 readynas kernel: sd 8:0:0:0: [sdg] Attached SCSI disk
Jul 14 16:25:07 readynas kernel: md: md0 stopped.
