thecypha
Nov 26, 2022Aspirant
ReadyNAS 314 Stuck on Welcome Screen
Hi guys, I have a ReadyNAS 31400 that is stuck on the "NETGEAR Storage Welcome" page when plugged in. It doesnt even make it to the boot menu. I've tried the reset with the paperclip in the back ...
sharmy
Nov 26, 2022Apprentice
I had this same issue on my 626X last week. Fortunately, it was still under warranty.
Per Stephen's post - do the disks spin up and does the fan run? If not, agree that it may be a power supply issue.
Have you tried booting with a new (blank) disk?
If none of this works, I suspect the memory may be the culprit. Of course, if you can't get to the boot menu, no way to initiate the memory test. If you have a spare module available, try swapping it out and testing.
