Dave21
Jun 05, 2013Aspirant
Readynas 314 support for UNIX / Share level security.
Hi all, We currently have an old 1000s that is is starting to have disk failures (as expected after such a long time). Functionally the unit works well for what we need although it is very slow. ...
mdgm-ntgr
Jun 05, 2013NETGEAR Employee Retired
Ah. I guess you don't want to use domain mode then.
Creating users and groups (if needed) would be the way to go. More than one user could login using the same credentials if you want, I think.
