kfrost
Apr 23, 2021Aspirant
ReadyNAS 314 volume issue after reboot
\]\\ Morning, I have a ReadyNAS 314 that we use for backup with Nakivo. Under the iSCSI tab there was a LUN. I had to reboot the NAS and now it's saying "No Volume exists. Netgear recommends ...
Apr 23, 2021Guru - Experienced User
kfrost wrote:
Apr 21, 2021 12:46:21 PM Disk: Disk in channel 1 (Internal) changed state from ONLINE to FAILED. Apr 21, 2021 12:46:20 PM Volume: Volume data health changed from Degraded to Dead.
The volume died before the reboot. It's not clear why the snapshot prune on 23 April succeeded.
You might try powering down, and then power up again with disk 1 removed. That might bring the volume back.
Also, I suggest confirming that disk 1 has indeed failed by testing it in a Windows PC with vendor tools (seatools for Seagate, Lifeguard for Western Digital). Run the full long generic test. Also, download the log zip file and look at the SMART status in disk-info.log. Also look in system.log and kernel.log for disk and file system errors.
- kfrostApr 23, 2021Aspirant
Thank you for this. I will give it a try and let you know the outcome.
- StephenBApr 23, 2021Guru - Experienced User
If it doesn't work, I suggest contacting paid netgear support via my.netgear.com.
No dice on removing drive 1. I did slave it off a windows box with no issues though.
