kfrost
Apr 23, 2021Aspirant
ReadyNAS 314 volume issue after reboot
\]\\ Morning, I have a ReadyNAS 314 that we use for backup with Nakivo. Under the iSCSI tab there was a LUN. I had to reboot the NAS and now it's saying "No Volume exists. Netgear recommends ...
kfrost
Thank you for this. I will give it a try and let you know the outcome.
Apr 23, 2021Guru - Experienced User
If it doesn't work, I suggest contacting paid netgear support via my.netgear.com.
- kfrostApr 23, 2021Aspirant
No dice on removing drive 1. I did slave it off a windows box with no issues though.
