amankyeld
Apr 03, 2015Aspirant
ReadyNAS 316 Hard-Drive Failure
Hi all, Recently installed readyNAS 316 six bay unit. Inserted 5 TB harddrive (1TB each, 5 pieces). Copied 2TB of data from old backup harddisk. Some files or folders are not accessible th...
mdgm-ntgr
Apr 11, 2015NETGEAR Employee Retired
You have two disks that are failing badly and are using a single-redundant volume.
Do you have another copy of the data that is on the NAS?
If not you will need to proceed carefully. You may need to clone one/both of the failing disks using dd_rescue.
You may wish to consider contacting support and purchasing a data recovery contract. Note that data recovery may be unsuccessful.
