Mrx2003
Dec 07, 2016Aspirant
Readynas 3220 + compatible UPS
Hi guys,
iam using a Readynas 3220 device with a more or less broken APC UPS (750VA - very old model! - not compatible with Readynas 3220 via USB slot). In the near future i want to replace the old model with a new one. Does anyone of you knows which UPS is 100% compatible with the Readynas 3220? It should have the the following specifications:
- Rackmount
- around 1500 VA
- long life batteries (changeable)
- RJ 45 interface (+ frontview)
- USB compatible with Readynas 3220
- good price/performance
- european powersupply standard (230V - Germany)
If there are any further questions, don't hestitate to contact me! Thank you for your response!
Best regards.
1 Reply
I don't know why you are looking for an RJ45 interface. Are you wanting the UPS to filter the ethernet connection?
