jguz007's avatar
jguz007
ReadyNAS 3220 not accesible from workstation
Drives seem healthy & was wondering how I can get the data?
I'm thinking about re installing the NAS OS. Will I lose my data on my drives if I do?
Any other recommendations?
Thanks!
  • StephenB's avatar
    Can you describe "not accessible"?
    • Are you unable to log into the admin web ui?
    • Are you unable to access the files with File Explorer?
    • Both?
    If you can log into the admin web ui
    • have you downloaded the log zip file?
    • If you go into the shares page and browse, are you seeing the files?
    • jguz007's avatar
      jguz007
      Thanks for the replay!
      I cannot log into the web interface. It does not come up. I have not tried to access in explorer but I'm guessing it would be the same being when I ping the IP, I don't get a response.
ProSupport for Business
