aknyc
Sep 27, 2018Aspirant
ReadyNAS 4 - Total capacity does not add up
Hi
I cant figure out what happened to my capacity. I have one 2TB disk.
I have about 270GB used in the data folders.
Two time machine sparse bundles are about 7GB and 750GB respectivel...
aknyc
Sep 28, 2018Aspirant
1. Where do i check snapshots? The attachment suggests i have no snapshots.
2. Also the balancing has hung! Any suggestions?
Many thanks!
Sep 29, 2018Guru - Experienced User
aknyc wrote:2. Also the balancing has hung! Any suggestions?
I suspect it hasn't hung. The more it's needed the longer it takes. Give it more time, and see if the completion percentage goes up.
What firmware are you running?
There might not be any. You can go to the share page in the web UI and confirm.
- aknycSep 29, 2018Aspirant
Thanks again!
You are right, balancing did ulimately finish. Tried defrag too. No increase in memory.
Please see attached re local snapshots. (from shares in web UI) Do I have any?
- StephenBSep 29, 2018Guru - Experienced User
The normal shares page will give you some indication on the snapshots for each share.
On the "recover" page you need to click on each share. That will give you a list of snapshots for those shares (which you can deleted from that page).
