jpttpiotr
Apr 26, 2016Aspirant
ReadyNAS 4 Ultra it is not visible resources
Hi Serial number : 2DK6190301627 Firmware : 4.2.26, raid 5 Starting RAIDar I receive the information that the excellent form. From the application level I log in to organizing, participations are...
Apr 26, 2016Guru - Experienced User
I suggest getting paid support from Netgear (http://support.netgear.com).
- BrianL2Apr 26, 2016NETGEAR Employee Retired
Hi jpttpiotr,
Welcome to the community!
Do you have RAIDar installed in your PC? Use it to detect your ReadyNAS Ultra 4 in your network. If it sees it, try to check if you can access the admin page. If not, check you local network connection and tell us the LED pattern or LCD status on the front panel.
I look forward to your response.
Kind regards,
BrianL
NETGEAR Community Team- jpttpiotrApr 27, 2016Aspirant
Hi
Thank you the answer :
1. RAIDar installed on a computer finds ReadyNAS and shows all diodes on in green,
2. From the computer I unite to the device as admin, as if all OK, volumes it is visible {apparently}, however I cannot record no changes of the configuration, simply they do not enter .
3. Ping to the device acts {works},
4. On the device the panel shows the address ip and the quantity of the vacant seat on disks, that is OK.
5. From the level Exploratora Windows of the device it is not visible {apparently}, what I additionally suppose is a result of the lack of the service making available resources for the system WindowsI greet
jpttpiotr
- StephenBApr 27, 2016Guru - Experienced User
It is possible that you have a filling OS partition. If you have ssh enabled, you can check for that. If not, it is something support can easily fix - ask about per-incident support.
Another option (if you have a full backup) is to do a factory reset of the NAS. Then you'd rebuild it, and reload all the data from the backup.
