jpttpiotr
Apr 26, 2016Aspirant
ReadyNAS 4 Ultra it is not visible resources
Hi Serial number : 2DK6190301627 Firmware : 4.2.26, raid 5 Starting RAIDar I receive the information that the excellent form. From the application level I log in to organizing, participations are...
BrianL2
Apr 26, 2016NETGEAR Employee Retired
Hi jpttpiotr,
Welcome to the community!
Do you have RAIDar installed in your PC? Use it to detect your ReadyNAS Ultra 4 in your network. If it sees it, try to check if you can access the admin page. If not, check you local network connection and tell us the LED pattern or LCD status on the front panel.
I look forward to your response.
Kind regards,
BrianL
NETGEAR Community Team
jpttpiotr
Apr 27, 2016Aspirant
Hi
Thank you the answer :
1. RAIDar installed on a computer finds ReadyNAS and shows all diodes on in green,
2. From the computer I unite to the device as admin, as if all OK, volumes it is visible {apparently}, however I cannot record no changes of the configuration, simply they do not enter .
3. Ping to the device acts {works},
4. On the device the panel shows the address ip and the quantity of the vacant seat on disks, that is OK.
5. From the level Exploratora Windows of the device it is not visible {apparently}, what I additionally suppose is a result of the lack of the service making available resources for the system Windows
I greet
jpttpiotr
- StephenBApr 27, 2016Guru - Experienced User
It is possible that you have a filling OS partition. If you have ssh enabled, you can check for that. If not, it is something support can easily fix - ask about per-incident support.
Another option (if you have a full backup) is to do a factory reset of the NAS. Then you'd rebuild it, and reload all the data from the backup.
- jpttpiotrApr 27, 2016Aspirant
1. On the device it {he, she} is 45% the vacant seat,
2. If I will log in as admin to the device and I will enter into the configuration of any participation it is placed as unavailable. If I will change the status for example on [to the reading {lecture}] and I will record, then then disappear all participations. I must reboot the device. Participations appear, but I cannot them make available.
3. I have the backup.
I greet- StephenBApr 27, 2016Guru - Experienced User
That's the data volume. You can't see the OS partition fullness from the admin UI. The OS runs on a 4 GB partition that is only visible if you log in with ssh. 4 GB isn't very large, and it can get filled by log files (and the ReadyDLNA cache).
jpttpiotr wrote:
3. I have the backup.Good.
Perhaps do a factory reset. You'll then need to reconfigure the NAS and restore all the data from backup. It is painful, but perhaps faster than experimenting, and it puts the system back into a known state.
