Thevenin's avatar
Thevenin
Readynas 4200 and SMC1000-2U APC UPS
Does anyone know if theses two are compatable?  I had a SUA1000rm2U, but it's been discontinued and this seemed to be the closest match.
Thanks!
Thevenin
  • BrianL2's avatar
    BrianL2
    NETGEAR Employee Retired
    Hi Thevenin,
    Haven't tested this. Would you mind if you will give it a try and update this thread on what happens?
    Kind regards,
    BrianL
    NETGEAR Community Team
  • Just wanted to let the group know that I did end up getting this APC model and it worked just fine.
    Hope it helps someone else.
    Thev.
    • BrianL2's avatar
      BrianL2
      Hi Thevenin,
      Thanks for your contribution! NETGEAR and other community members surely appreciate it :)
      Kind regards,
      BrianL
ProSupport for Business
