ximen
Apr 27, 2021Aspirant
ReadyNAS 4220s not creating shares
Hello! I can not create new shares on ReadyNAS 4220s, ISCSI LUNs also could not be created. When I try to add share, web interface simply restarts. In console (journalctl, dmesg) I can see readynasd ...
ximen
Thank you for your attention!
No, none of partitions are full:
root@DATANAS:/var/log/readynasd# df -h
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 1.3G 2.4G 36% /
tmpfs 3.9G 0 3.9G 0% /dev/shm
tmpfs 3.9G 11M 3.9G 1% /run
tmpfs 2.0G 1.7M 2.0G 1% /run/lock
tmpfs 3.9G 0 3.9G 0% /sys/fs/cgroup
/dev/md127 5.5T 172G 5.3T 4% /HyperV
/dev/md126 11T 3.7T 7.3T 34% /Datanas
/dev/md126 11T 3.7T 7.3T 34% /apps
/dev/md126 11T 3.7T 7.3T 34% /home
/dev/md126 11T 3.7T 7.3T 34% /run/nfs4/Datanas/IT
Apr 27, 2021Guru - Experienced User
Was the root ever full? There is a script you could potentially run, but I'm not sure if if it will help. https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh
Obviously confirm that the volume isn't in read-only status first.
- ximenApr 27, 2021Aspirant
Thank you very much for help! This script turned out to be very useful - it have made all shares I've tried to create visible, so I have now at least one way to create new shares.
However readynasd still restarting and unable to create iSCSI LUN...
I'll try to find something useful about iSCSI in this script.
- StephenBApr 27, 2021Guru - Experienced User
How did you try to create them? Normally shares are btrfs subvolumes - is that what you created?
When I try to create share via web UI the only thing being created is btrfs subvolume. Then readynasd faulting. In result share (subvolume) exists in filesystem, but not being exported via Samba nor showing in UI. I also tried rn_nml with same result. After applying suggested script they begin to work properly.
